head scratcher - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2005, 05:25 PM
head scratcher
My 85 monte has been sitting since December, I took it out for a spin today and every time i was cruising and would hit the breaks, I'd hear a clunky sound come from the back of the car. It feels almost like the back of the car wants to come apart. I know it's not the body mounts, I just replaced all of them last summer. I also get the same problem when I turn hard.
Does anyone know what this could possibly be?
Old 07-03-2005, 06:36 PM
poncho62's Avatar
Wiki Edits: 5
I'm guessing rust on the drum surface, due to sitting.
Old 07-03-2005, 07:00 PM
aka Duke of URL
How about control arm and panhard bar bushings? Is there a sway bar on it? Shock mountings?
Old 07-04-2005, 12:32 PM
30desoto's Avatar
Dodge ain't all bad
Jzarczyn
You might check your transmission mounts, they can cause this problem, but feel fine when doing normal driving, also check your shocks if one is flat may cause a shift when you brake.
30dee
Old 07-12-2005, 07:42 PM
let 'er go!
85 monte c
Dude, check your rear brakes. they are in need of some tlc. dont skimp and machine the drums, buy new ones. You should also check the front brakes. Make sure all brake parts are ok. (including those darn parking brake cables!).
3.8 Ford Head Gasket Questions RCastle Engine 17 04-11-2005 10:14 AM
cylinder head cracked?!?!?!?! Blob Engine 4 01-24-2005 06:12 PM
Blown Head Gasket???? hmmm Engine 4 11-10-2004 10:20 PM
bowtie head ?? and hp? 64 nova Engine 0 09-09-2003 10:48 PM
A Real Head Scratcher Jim Weeks Electrical 5 03-07-2002 06:33 PM
