head STUD sealant - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-09-2014, 07:18 PM
thinwhiteduke's Avatar
Living In The Past
head STUD sealant
Hey,, I know this subject been flogged already , but is this stuff good for head stud sealant sbc? Or should I use Teflon paste or tape. I used the GM Sealant last time and it was s hit , three leaked! ... It was great for gaskets though!!!
It's a street strip engine that's not coming apart regularly, hopefully...
Keep in mind they're studs, not bolts.
Thanks
Duke
Old 01-09-2014, 07:44 PM
Banned
I use the same stuff as bolts. Cheap plumbers tape. I haven't used too many sets of head studs though.
Old 01-09-2014, 07:48 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Thanks
Duke
The main thing to remember using any sealant is that the threads in the block and the studs/bolts need to be cleaned. I personally use the Aviation Form-A-Gasket and have never had a leak. The Indian Head is "similar" and should work fine. If you really want to be sure, use the Teflon tape on the stud threads and then a light coat of Indian Head sealer on the Teflon tape and install the studs. If you use Teflon tape, make sure you "stretch" it when wrapping around the stud threads so it will get down into the threads instead of just laying I on top of the threads. JMHO, I'm sure others will have a different way.
Old 01-09-2014, 08:43 PM
CraigK's Avatar
Last journal entry: For a change of pace
Blue leak lock ((NOT blue thread sealer)) both by locktite. If you really are antsy use yellow teflon ( yea I know its 7 bucks a roll ) and then blue leak lock
ontop of the yellow tape. You only need two wraps of yellow tape. I just use blue leak lock, unless I have one of those spidy sense tingles, then I do tape and leak lock. That combo never failed me. But, I sure never tried all the products out there. Other busy swear by other stuff.
Blue leak lock Stays soft and yet grips enough for some thread lock properties.
I swear it has some blue thread lock mixed into it.
Old 01-09-2014, 09:12 PM
Banned
I don't think you can put it on a bolt without stretching it tight, that tape doesn't stick on it's own... Like it's made of Teflon or something.
Old 01-09-2014, 09:14 PM
4 Jaw Chuck's Avatar
Loctite 518, clean both threads well. Lightly torque head on to keep studs aligned, let cure for 24 hours.
— Han Solo
Old 01-10-2014, 07:29 AM
S10 Racer's Avatar
Yes you can..... Try it.
Old 01-10-2014, 09:25 AM
Banned
I have, it doesn't stay put unless you stretch it while you put it on, it moves all over the threads.
I've gone through quite a bit of that tape. Never had a problem either, just wrap it with 3 layers, light coat of oil or assembly lube, and torque 5lbs over what it calls for.
Again, it's not "by the book" but its cheap, easy, and effective.
If anyone has a way to measure how much it really alters the torque specs I'd be interested to know. I just use 5lbs as an adjustment.
Old 01-11-2014, 09:59 AM
I have head studs from arp on both of my small chevy 350's and the older one I have which was built in 2007 plain old Teflon tape was used and they have been fine ever since. Now on my newer 350 which was built in 2008 I used head bolts and then switched to head studs two years ago cause of other issues and at first we used the Teflon paste and it was a disaster and never hardly sealed. Then we took it apart and redid with Teflon tape and then added Indian head over the Teflon tape and it sealed like a charm. Recently last spring I switched the heads and only Teflon tape was used and all but four studs sealed up just fine and I am going to take each one out at a time and reseal the dang things once again. My threads were as clean as you can get outside a new block and it was chased and cleaned and aired blown out. From what I read sometimes its a hit or miss with these things and most of what works is a Teflon tape along with something like permatex no 2 or indian head or the locktite blue sealant that usually works pretty well for the most part with out having any issues.
Old 01-11-2014, 03:46 PM
Living In The Past
Thank you all for your input. The threads in the block have been chased out with a "good quality" tap. No metal came out and the threads are now shiny new looking. I will rinse with thinners and blow dry also to ensure they are squeaky clean.
Seems, as usual, there are more ways than one to skin a cat and this time the tightly wound Teflon tape with light coat of Indian Head is sitting well with me in my gut. My gut feeling are usually right for me. Last time when I used just the GM sealant, it seemed a bit runny to me like it lacked enough viscosity to hold up to the task of staying where it should until everything was torqued up, and sure enough, I had to redo three studs.
Does anyone remember the final torque spec (I'll do in three stages) for an ARP stud in SBC?
I lost the paperwork for them. 70f/lbs comes to mind...
Again, I appreciate your help
Duke
Head Bolt Sealant? 39chevy Engine 10 12-15-2012 12:52 AM
Do these cylinder head bolts need sealant? 0pyders Engine 12 01-23-2011 04:30 PM
Rocker stud sealant 2old2fast Engine 1 04-16-2010 06:40 PM
Head bolt sealant moretork Engine 2 09-26-2009 04:50 PM
sbc 400 head stud...sealant? 6speedwagon Engine 3 01-28-2004 11:56 PM
