head studs and sealer qs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2008, 07:11 PM
hey guys, just wondering what do you guys use to seal the threads in your head bolts/studs, and also do you screw the studs right in at first or better to wind them down with the nut ,,,have heard a few different ways ,,,just after the rigt way ,,,,,cheers chris
Old 08-24-2008, 07:48 PM
I use verry little saler if needed on a stud or bolt I use liquid teflon it has worked for me going on 20+ years now. On tighning the studs I run them down by hand with a speed handle and a stud installer then tighten them 30 inch pounds to make sure they are seated in the block. ARP says hand tight but that is just a little more than hand tight and again I have never had a problem.
Head bolt sealer T-bucket23 Engine 20 04-11-2008 04:35 PM
Head stud sealer Stroker56 Engine 9 01-15-2006 01:28 AM
Head studs in...now??? HemmiGremmie Engine 11 06-14-2005 05:28 PM
Loctite on Rocker Arm Studs and Head Bolts? Bakdok Engine 13 03-30-2004 09:25 PM
Sealing head bolts pcesak Engine 10 05-13-2003 06:42 PM
