head swap????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2002, 08:51 AM
Post head swap?????
i have a 1978 302 in my ford truck.
i also have a 351m out of a t-bird.
i want to know if its possible to swap heads from the 351 to the 302 .the 351 heads have been redone .the 302 heads are shot.warped an cracked around the exhaust valves.the 302 was just rebuilt but heads were not redone . i am short of cash and hoping that this swap will work has i cant afford to get new heads .any help would be wonderful.
Old 10-07-2002, 09:29 AM
Post
I am not familiar with ford motors, but on Chevy and Pontiac if you bolt a bigger cubic inch motor head on a smaller cubic inch motor you will loose compression. the compression chambers will be bigger for the larger displacement engine and depending on if it is a high or low compression engine, when the heads are bolted onto the smaller motor the compression will drop significantly. I know it's not good news, but hope it helps.
Old 10-07-2002, 09:56 AM
aka Duke of URL
Arrow
[quote]Originally posted by muscles:
<strong>i have a 1978 302 in my ford truck.
i want to know if its possible to swap heads from the 351 to the 302.</strong><hr></blockquote>
Yes, it can be done. The swap is referred to as a -CLEVOR-.
It is not cheap as you will need Cleveland style pistons, a non-production intake manifold and some machine work.
I believe you will be better served to look around for a set of small block take-offs that will get you running, or put the complete 351M in the truck.
Old 10-08-2002, 07:37 PM
woodz428's Avatar
Troll Hunter
Post
As stated in can be done. Stock cleveland (351 pistons will work and there are a few intakes that are designed for the swap, we called it the Bogus Boss back before Ford started releasing all the trick heads. The cleavor is actually a block designed for Cleveland heads but with the oiling system of a Windsor (much more mahvelous than the Cleveland).Unless you've been collecting Ford stuff for the last 30 years or know someone that has the swap wouldn't give as good a result as a good set of any of the current aftermarket Windsor heads and would probably end up costing the same or more.
