Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - head upgrade disappointment
  #22 (permalink)
Old 08-27-2012, 05:40 PM
JeffB's Avatar
JeffB JeffB is offline
You may want to look at swapping to this cam:Lunati 60104 - Lunati Voodoo Camshafts - Overview - SummitRacing.com you have the springs to handle the additional lift,this cam is designed to bring back some of the low and mid-range you lost with the 210cc heads please read the description at the bottom of the specs,as mentioned earlier do advance the cam 4 degrees,some rear gears in the 3:70's will be a big help too.
