head upgrade disappointment
Hi guys,
finally finished head swap on my 350 sbc Originally had camelhumps un ported with 1.94 1.5 valves. Upgraded to 210cc heads 64cc chambers aluminium. 2.02 1.6 valves. I can say there is very little difference with the performance! Flat top pistons, Cam,carb,headers all left as they are,cant see what Ive done wrong. Engine specs 350 +60thou,holley 600v/s,edelbrock rpm intake,mallory unilite,magnum 480/480 lift and block hugger headers, any ideas?? 3.09 rear gears T5 manual trans Thanks in advance |
what kind of aluminum heads?
Skip whites procomp heads, they are suppose to be around 400 horsepower,cant see my camelhumps anywhere near that!
To a very large extent the engine behaves in concert with the mixture velocity of the intake system. Physics tells us that for a given amount of flow, the flow velocity of a large pipe is slower than in a smaller pipe. In effect below some critical RPM the larger port head has lost so much flow velocity that it can no longer get the cylinder filled in the time allocated by the cam's duration and amount of lift. In fact the velocity may be so low that the piston rising on the compression stroke where the valve is still open will actually backward pump mixture into the intake and out of the carburetor, this is reversion. This is why using large port heads and big valves always reduce lower end performance. A problem I have with Skip White's heads, which are ever so cost attractive, is that they come in big and bigger. They just are too much for a 350 unless you're going to take it over 6000 RPM. Back in my Ford Cleveland and Tunnel Port days I used a lot of marine grade epoxy to shrink those sewer pipe sized ports down to size; you may be in the same boat. Bogie |
Now for the problems- are you certain your old heads were 64cc's? If the valves were changed, or those heads were ever milled you may have been closer to 60cc's or even less, which means you lost compression. Next, you have a pretty terrible exhaust, which on heads with larger runners can lead to reversion as already indicated- fixing your exhaust will fix that problem. Next you probably didn't retune your carb, which can have a BIG effect on power. Next, what head gaskets did you use, which kind did you replace? There's more compression loss there. Also, anytime you switch from iron to aluminum you need about a full point more compression to make the same power, you more than likely lost compression which means you went in the completely wrong direction there. So to fix this mess of a poor installation you need to do a few things- pull the heads off and mill them down you'll likely need to mill a considerable amount to get your compression where it needs to be- depending on your cam and pistons. Get a decent set of headers (this part alone will give you more power than you had when you started). And get your carb properly tuned and/or replaced. Ignition timing also needs to be correct, but i assume you can figure that part out. Fix those three major points and you'll start seeing some serious power. the next item would be having a valve job and bowl port work done on your new heads, but that can be a little costly. Lastly, if those camel humps were really expertly ported they may flow more air through a smaller valve- which is always a good thing for a street engine. |
Oh well bit disappointed now!
Hi
bogie and engineczar both of you are spot on! It does seem to at least match the camels at lower revs but then it wants to rev further than them! The advertised duration is 280 and at .50 intake/exhaust is 230 degrees. To be honest I dont fully understand these figures. Skip whites website states with a cam around 480/510 lift it dynos at just over 400 horsepower on a 350. Do you think changing rear gears and a bigger carb will help, I was considering a cam change as well if you have any suggestions? Thanks again |
Bogie |
My rear gears are 3.09 and tyre diameter is 23 inches if that helps My car weighs 2600 lbs Realistically what horsepower do you think I might have? What should I expect down the strip? Sorry for all the questions! Last edited by dave350v8; 08-27-2012 at 01:47 PM. |
a 2600 pound car with 400 hp should run low 12s or better.the tires are only 23 inches? I think the heads are too big for a stock 350.If you are fast with a wrench the full the front off and advance the cam 4 degrees,couple hours and gaskets. If that perks it up then what bogie said about reversion,,,
NOTE:the top end increase in HP,you might not feel by seat of your pants driving even if you got 25 more horses. If advancing the cam changes things a lot,then retuning is in order,probably cam and intake. what you have done is put on entry level race heads on a very mild street engine. Think of it like putting an 850 double pumper on a stock 283 |
Yes I see what you mean! What does advancing the cam do as you have suggested?
Would a bigger carb help now,I have a 650dp on the shelf and a 750v/s Yes my tyres are 23 inches in diameter! do you think that will be ok with the T5 ratios and 3.9 rear? I doubt I am anywhere near 400 horsepower now! Thanks again |
advancing your cam will make more cylinder pressure so more bottom end,generally,it robs from the top end though.This will tell old bogie what is happening and he will give 2 pages of ideas later. do 1 thing at a time.change the carb first and see what happens then cam or the other way around
Will try advancing cam then! Will do carb first as this is 30 minutes to do!
Would I gain more by putting in a bigger lift cam though? thanks Last edited by dave350v8; 08-27-2012 at 02:50 PM. |
| Head light upgrade | 57halfton | Hotrodding Basics | 6 | 12-05-2011 12:41 PM |
| Disappointment with new cam/head swap | Chevy21 | Engine | 33 | 07-13-2009 05:48 PM |
| My GM headliner, what a disappointment. | ViperMonster800 | Interior | 23 | 07-06-2009 10:36 PM |
| SBC head upgrade | upstand2 | Engine | 7 | 09-04-2005 03:39 PM |
| CCR was a big disappointment | Centerline | Hotrodders' Lounge | 5 | 02-24-2004 12:03 AM |
