I'm taking my engine (SBC) up to another level of performance and will be having some head work done. As I will be going to about a .512 lift I'm going to have screw-in studs installed and the springs replaced with ones capable of this high lift. I will be going to full roller rockers and have no experience with them. Is there any special work that needs done to accommodate this style of rocker? I read about stud girdles, are they needed? While I've got the heads off I want to get everything done and out of the way. Thanks for your input it is appreciated.
I would get 1.6 rockers. You will need to elongate your pushrod slot to use them. There is a too called Luis tool that does this using a hand drill. You won't need stud girdles.
No work is needed. The 1.6 is good if you are wanting a little more valve lift, but since most oe heads see very little increase over .500 lift it depends on the cam specs.
Chris
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
