Header clearance 4.3 v6 tbi 91 Astro - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2010, 05:08 AM
First time hotrod builder. 1951 Chevy shortbox pickup. Donor vehicle is 91 Astro, 4.3 v6 TBI. Just installed the stock headers and having steering clearance issues. Using Borgeson knuckles, heim joint,dampening knuckle, & DD shaft. I am considering using an aftermarket header to help get the clearance required. I have gone online and researched many different types of headers from weld in kits to ready to install units. Before I order & because I have no previous experience, I'm hoping someone can give me some guidance as to what type of header will work & fit my application?
As you will see in the attached pics, I am using wooden dowels to determine the right lengths & mockup before cutting the DD shaft to the best possible lenghts for the application. So far the best I can get is about 3/8" clearance between the shaft and the stock header. Would it be a good Idea to consider a heat shield?
ID:	46485   Click image for larger version
ID:	46486   Click image for larger version
4.3 V6 - Balance shaft? Torque454 Engine 12 03-09-2009 05:53 AM
4.3 V6 no ps / AC, serp needs idler pulley user151 Engine 2 12-22-2008 06:23 AM
Camaro V6 to V8.. anyone ever done it? C10 Engine 3 11-23-2007 12:12 PM
91 rs tbi 305 to 350 carbed tat2 Engine 2 05-15-2004 06:46 PM
4.3 to 350 swap in '91 Chevy V8 S-10 Engine 0 06-10-2003 01:35 PM
