header clearance to shifter linkage for steering column - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2013, 02:17 PM
i have a 69 camaro i just put a 496 in, and the headers are hitting the steering wheel lockout bracket. i asume when you put the car in gear (700r4) it unlocks the steering wheel. can this be removed and the rod scured in the unlock position? new hot rod guy any help would be appreciated.
Old 03-24-2013, 03:32 PM
It actually works the other way around. When you turn the key to unlock the steering wheel, the linkage also unlocks the shifter. Once GM went to the federally-mandated steering wheel and shifter lock, they also changed the neutral safety switch design such that even floor shift cars used the steering column-mounted NSS. If you have an aftermarket shifter with it's own NSS or if your car still has the console-mounted NSS, then you can remove the backdrive linkage with no problems. Just be sure that the steering column collar (where the shifter would be on a column shift car) remains fully counterclockwise. If it rotates at all, the internal mechanism prevents the key from turning to the lock position. If that happens, just turn the collar CCW with your hand.
The Following User Says Thank You to joe_padavano For This Useful Post:
ktrmoses (03-24-2013)
Steering shaft - header clearance? staleg Suspension - Brakes - Steering 5 03-11-2011 06:08 PM
How to use 1954 Steering column shifter for T350? Riot Racing Transmission - Rearend 9 12-11-2010 07:43 AM
Header collector in way of column shift linkage Warrant Engine 4 08-29-2006 12:26 PM
C6 shifter linkage help? Steve-0321 Transmission - Rearend 3 02-09-2006 12:08 AM
Shifter Linkage 1slick1 Transmission - Rearend 4 11-03-2005 02:39 PM
