Header clearence on 3rd gen camaros - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2006, 11:46 AM
Yeah i know they are ugly and not a real camaro, but i am buiding one anyway. I am almost ready to make the exhaust and was wandering if anybody had any experience with this. Is there room after a full lenth header to fit pipe from the driverside to the passenger side since by looking under the car the passenger side looks like the olnly way out. For clearence I am going to run two 12" Dynoflow tube mufflers and would like to keep it true duals (no y-pipes!) And maybe route it out right infront of the back wheel or possibly just run turndowns right infront of the rear end. I saw a foourth gen with the turndowns and it ran the pipe down the center near the trans tunnel (I did not see what length headers, only saw under it while it was driving). Is there room to do this on a '84? Thanks for the help.
(Also it will probably only be semi-legal exhaust, no cats)
Old 01-27-2006, 12:07 PM
firestone's Avatar
http://teamrfc.gospelcom.net
You can have a custom system bent and run both pipes down the passenger side. They will still be close to the ground, but it works ok. I have seen it done to where true duals come all the way out the back using this configuration.
Adam
What is the best year for 3rd gen Camaros? Big72Chevy General Rodding Tech 7 12-06-2004 07:29 PM
SCCA CAN AM TRANS AM Series 1st Gen Camaros texasrat Hotrodders' Lounge 6 10-01-2004 05:24 PM
will a 4th gen camaro rear end fit 3rd gen? 84Z Transmission - Rearend 2 05-13-2004 07:51 PM
After Market mods to 3rd Gen F-Body Kaylah Suspension - Brakes - Steering 4 03-15-2003 03:57 PM
Anyone have a pic of a yellow 3rd gen camaro? stonedchihuahua Body - Exterior 5 12-17-2002 10:18 PM
