Header collector in way of column shift linkage - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2006, 05:48 PM
Warrant's Avatar
72 Nova, 65 Rambler, 37 Chevy
I recenalty installed my new 350 into my 72 nova with th350, when I put my headers in the shift linkage is in the way(header collector is right in the middle of where the hole in frame is and where it hooks up to the trans)
The car was origanly a poweglide column shift, the th350 was a 75 malibu floor shift. Headers are flowtech afterburners.
What can be done? I Think I may be able to weld up something were the origanal linkage arcs over the top of the collector.
Also on tube of the header just barely clears the steering box(able to stick several sheets of paper between enuff to see between them) is that ok? or do I need to dent the tube???
Thanks
Old 08-28-2006, 06:37 PM
MI2600's Avatar
Member# 3287
Sounds like you have the wrong headers for your car. If they are new, take them back before you go denting them up.
Old 08-28-2006, 07:47 PM
Warrant's Avatar
Must be the company....I checked the number their are definitely for X body car and the instructions list 1972 nova for automatic transmission only.
Old 08-28-2006, 09:00 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
I have had 2 sets of headers on my car and both of them were close to the steering box. I think its normal for us. On my ceramic coated one it only hit enough to scuff the coating a little. I cant say anything about the trans problem as Ive always had a floor shifter. Even when it was a 6.
Old 08-29-2006, 12:26 PM
Hippie's Avatar
Last journal entry: HEI comparison.
I believe Lokar or Gennie Shifter makes a flexible AT column shift linkage that will get you past your header issue.
need help on converting column shift too floor shift . jody chevelle Electrical 1 11-29-2005 08:29 PM
Column shift on a 50 Hudson?! jsrail Transmission - Rearend 3 11-02-2005 08:08 AM
best way to adjust shift linkage? lemans-tom Transmission - Rearend 2 09-08-2005 02:54 AM
c10 - th350 to 700r4 swap column shift 70chevyc10 Transmission - Rearend 7 10-25-2004 09:35 AM
column shift into 54 chev PU DV8 Suspension - Brakes - Steering 6 04-22-2004 08:29 PM
