Header flange change - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2013, 06:11 PM
I got a buick 350 which im about to take out a put a sbc motor in i wanted to know if i could use my buick headers if i change the flage to a sbc so i wouldnt have no issues with clearance on the motor swap.
Old 01-30-2013, 12:02 AM
327NUT's Avatar
Hard to say about the clearances but the Buick and Chevy share the same exhaust port configuration. I don't know how close the ports are off but with some good fabrication you should be able to change out the flange. Make sure you buy 3/8" thick flanges though, more material to weld to and less chances of warpage. You can find the flanges on ebay, I bought a nice set of 3/8" for $45...shipped.
Red glow at header flange? runndmy Engine 12 09-04-2011 08:51 AM
Red glow at header flange? runndmy Engine 1 09-03-2011 10:09 AM
welding a header flange to the head? d1mbu1b Hotrodding Basics 19 03-09-2011 09:57 AM
Straighten bent warped header flange 001mustang Engine 13 06-12-2009 10:45 PM
header flange warped??? fireforsin Engine 6 02-28-2006 08:28 PM
