header flange warped??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2006, 06:33 PM
fireforsin's Avatar
Novaaaa
i am pretty sure one of my header flanges that connect to the cylinder heads is warped causing a very annoying exhaust leak. is there a way to fix this?
thanks,
mike
Old 02-28-2006, 06:38 PM
fireforsin's Avatar
Novaaaa
i already tried replacing the exhaust gaskets as well and making sure the bolts are tight.
Old 02-28-2006, 07:58 PM
302 Z28's Avatar
You might try and use a set of dead soft solid copper header gaskets. They are a little thicker and hold up way better than typical header gaskets.
Vince
Old 02-28-2006, 08:02 PM
broncoII88's Avatar
Do the right thing...
You could try removing the warped header and flattening the flange with a hammer (dead blow) on a flat surface, but it'll probably just warp again. How thick are your flanges?
My dad told me about an old 69' firebird he had that he put headers on it. The headers were made by an unrecognized manufacturer and my dad payed for it in the end. He said the driver side flange warped and didn't fit right. So he had to keep slapping on this exhaust sealing putty which would crack shortly after applying it.
Old 02-28-2006, 08:05 PM
poncho62's Avatar
Wiki Edits: 5
SB Chevy?
Cut the flanges between the pipes, so they are 3 separate flanges. This allows the leaker to conform to the head better.
Old 02-28-2006, 08:44 PM
fireforsin's Avatar
Novaaaa
i have the hooker comp headers on my SBC. if i cut them is there more chance for them to crack near the bolt holes. also the flanges are supposed to be advertised as being super thick to prevent warping.
Old 02-28-2006, 09:28 PM
If you pull the header off and place a straight edge across the ports you should be able to see where it is warped. Most headers have a weld bead built around the port and you can build up the low one and file it flat to match the rest. Its a pain but it worked on my blockhuggers. Also use the black felpro exhaust gaskets and don't over torque. Run the engine, cool it down then re torque.
Oljoedog
Live long race hard
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 10:21 PM
Header Painting How To Full Throttle Engine 33 03-08-2006 02:06 PM
Oil filter hitting header???? Robbie Engine 19 04-09-2005 10:35 PM
Header leak help tm454 Engine 2 12-18-2003 11:53 PM
Header flange went bye bye Wmarden Engine 8 11-08-2002 09:49 PM
