Header flange went bye bye - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2002, 06:36 PM
Last journal entry: Some pics
Thumbs down Header flange went bye bye
Well at least I got the heads off. I was in the process of pulling the heads off, and the one last bolt to the header was a real pain. The next to the last one wasn't much better, but at least I eventually got it off. So there I was trying the old squeeze the living crap out of the vice grips to get a rounded bolt technique. Even with that I couldn't get the last one off. So I tried yanking the gasket out to get a little wiggle room. It sort of worked, and then I saw it was a slot not a hole. SO I tried just yanking real hard on the heads and turning tthem every which way.
The heads did come off, but so did the flange to the middle tube of the header. So I want to know if I can get a new flange welded on my headers. Shouldn't be too complicated, but can it be done. I have a shop in mind and maybe I should just ask him.
Old 11-07-2002, 06:51 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
I would think that any competant welder would be able to do the work for a nominal fee.
Old 11-07-2002, 07:05 PM
4 Jaw Chuck's Avatar
Post
Yep.
— Han Solo
Old 11-07-2002, 09:43 PM
Post
Thanks, I thought so. I may well see if I can get a new one instead of replacing the old one. The old one was rusty to the point I was able to chisel(with a flat head screw driver) off chunks. There was a good layer beneath that, but still.
BTW what is the general opinion on using covering wraps over the headers to keep down under hood temps? I am considering it because it would probably help the battery cable live a little longer, plus I think keeping underhood temps down is a good idea. One downside is I think it would be very easy to make it look bad with the wrap. As opposed to a good paint job.
[ November 07, 2002: Message edited by: Wmarden ]</p>
Old 11-07-2002, 11:27 PM
Post
Wrapping the headers will shorten their life considerably, I don't recommend them. Even the blankets will shorten the life too.
Some of the guys here on the forum have had their headers Jet Hot coated which coats the header inside and out and actually makes them last longer...although I'm not sure it reduces underhood temps any.
I don't believe there is any foolproof product or method that will achieve what you want without shortening your headers life, the stainless heavy gauge headers seem to stand up to wrapping better but they still degrade faster than usual if you go this route.
Sorry to say there is no perfect solution to the problem. I have used insulated vented stainless shields on industrial stationary engines to reduce noise and transmitted heat with tubular exhausts and it works quite well, having adequate air flow through the shield is important and using quartz glass matting is required to withstand the heat.
— Han Solo
Old 11-08-2002, 02:02 AM
Post
Thanks again, I knew I had heard something negative about them, but just could not remember what it was. Given the fact that I just popped a flange off I think wraps would only be a bad idea.
Old 11-08-2002, 06:02 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Wraps would be better than the thick chunks of flaking rust!! Seriously, I am a huge fan of the Jet-Hot type coating. If you are serious about keeping your headers alive, this stuff will give you at least a decade. I am close to that milestone for the headers on my Willys and they still look like new, inside and out! I am not prepared to say they will last forever but I don't see any signs of mortality yet. Also, they do lower temperature a little, not by insulation as much as by greatly reducing radiant heat loss since the surface is very shiny. Since the radiant heat loss component of hot headers is significant, there is a measurable heat loss reduction.
Also, put some anti-sieze on your header bolts this time!
[ November 08, 2002: Message edited by: willys36@aol.com ]</p>
Old 11-08-2002, 07:35 PM
Post
What would it cost me to Jet-hot coat them? Is it available in a rattle can(or even for a spray gun) or is it more like powder coating in that is an involved process?
Old 11-08-2002, 08:49 PM
Tazz
Cool
Got a set of Sanderson headers for my 53 chev. Rattle caned the hot coat in and out as best I could, didn't want the extra cost of the dipped headers so far they are great. Look great after the first season too, no change since I rattle caned them. The cans cost about $10 each, I used two cans.
