Header gasket/collector gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2006, 11:51 AM
Jmark's Avatar
Does anyone have a favorite header or collector gasket that actually lasts?
I had the Mr. Gasket high dollar "Ultra seal" header gaskets on this time, left side lasted 16 months. Went back to the basic white Mr. Gasket since spending 22 bucks on the first ones was pretty much a waste.
I also tried the super fancy whizz bang soft aluminum collector gaskets on my truck and my sons truck. Those things popped and clicked and moved all over the place in the heat cycles. Went back to the Mr. Gasket basic white gaskets today since I already had all my tools out.
Old 11-21-2006, 11:56 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Not much you can do with the collectors. Looks like the flanges are bent. You will never get a seal to stay in there. Keep the aluminum ones or cut off the collector and change flanges.
Stock printed metal ones last the longest for me. Good bolts help too. So do good threads. Put the metal to the header side. the last set I used is going on three years. I even use them and gasket match the port's to fit my race engines.
Old 11-21-2006, 12:00 PM
Guy Hiltz's Avatar
I cant say much about collector gaskets as my headers/exhaust are welded together,but I have had the cheapie Mr Gasket ones on for a couple of years now,even had them off and reused them last time I had the motor out.I do pay close attention to keeping the exhaust bolts snugged up,I usually do this once or twice a month,this seems to help quite a bit.If your headers get a little loose this can cause gasket problems.
Old 11-21-2006, 02:10 PM
Mustangsaly's Avatar
I like the copper ones, thats all I use now. I had a 390 Ford yrs ago (I don't remember the header brand name) It seemed no way would I get 10 to 14mons on a set of header gaskets. I had one leaking and when no one in town had any header gaskets someone offered me a stock exhaust manifold gaskets, being desperate I put a set of stock exhaust manifold gaskets on, and never had another leak. I haven't tried stock exhaust manifold gaskets since. but it was a easy swap, there was no a/c no extras in the way it was a 69 Ford p/u.
Mustangsaly
Old 11-21-2006, 02:38 PM
On header flanges we always use Fel Pro, never an issue unless the flange is warped or the bolts are not tight. On the collector fireplace caulk is pretty bulletproof.
Old 11-21-2006, 03:00 PM
Irelands child's Avatar
Take a look at Earl's. I had a problem with my GT40 heads and the interface with Sanderson headers and had tried several other brands for fit up. I also had to use Breslin header bolts, again because of the headers. Even ARP studs wouldn't fit. Reasonably priced tho not cheap
Below is the Earl's description - you just replace the insert rather than the entire gasket assembly.
"Pressure Master Header Seal, for Ford 289–302–351W (Except Boss), Pair – Designed and manufactured for Earl's by Parker–Hannifin Corporation, these seals are the first High Performance Seals developed to solve automotive sealing problems using Aerospace Technology.
Installation Notes
The graphite foil sealing inserts can be replaced in the aluminum retainer, making it an economical solution to tough sealing problems. Replace the seals on a smooth flat surface using even pressure for best results.
Features
Uses Aerospace Technology
Reusable/Adaptable
Graphite Foil Sealing Inserts
Virtually Leakproof
Seals Up To 1200% Better
Superior Torque Retention
Longer Lasting Pre-Load
90% Break Loose Torque"
Dave
Irelands child
Old 11-21-2006, 03:21 PM
edge's Avatar
Time is short, are you ready?
I second the Earl's.
I have used them with great success.
Ed
Old 11-21-2006, 03:26 PM
poncho62's Avatar
Wiki Edits: 5
Just like johnsongrass1, I use the stock metal backed ones that you get in gasket sets. I have found over the years, that its more the bolts you use and how you tighten them more than what gaskets you use. When installing new gaskets, check for tightness the 1st few times you heat the engine.
Old 11-21-2006, 03:55 PM
Normally I would agree with you - except the @#$* GT40P heads w/Sanderson headers didn't leave me much of a choice along with the expen$ive header $tud$. But these Earl's gaskets are nice !!!
Dave
Irelands child
Old 11-21-2006, 04:13 PM
On the wife's Small Block Vette, we had header gasket failure about every 3 to 6 months. Diffent gaskets, same problem. Finally, I threw two solutions at the problem at one time. Soft Copper Gaskets (Mr. Gasket, I think) and Stage 8 bolts. Whether it's the bolts not trying to come loose, or the gasket being indestructible, I don't know. I only know the combination works. The headers aren't fancy, just a pair off-brand shortys, but they don't leak anymore.
Pat
Dumb Header Reducer Question Mustangsaly Hotrodding Basics 6 10-19-2006 09:05 PM
Header Painting How To Full Throttle Engine 33 03-08-2006 02:06 PM
Header wrap on one section of header Sparky06 Engine 4 07-27-2005 11:01 PM
Oil filter hitting header???? Robbie Engine 19 04-09-2005 10:35 PM
Header leak help tm454 Engine 2 12-18-2003 11:53 PM
