Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Header gasket/collector gaskets
Old 11-21-2006, 03:00 PM
Irelands child's Avatar
Irelands child Irelands child is offline
Take a look at Earl's. I had a problem with my GT40 heads and the interface with Sanderson headers and had tried several other brands for fit up. I also had to use Breslin header bolts, again because of the headers. Even ARP studs wouldn't fit. Reasonably priced tho not cheap
Below is the Earl's description - you just replace the insert rather than the entire gasket assembly.
"Pressure Master Header Seal, for Ford 289–302–351W (Except Boss), Pair – Designed and manufactured for Earl's by Parker–Hannifin Corporation, these seals are the first High Performance Seals developed to solve automotive sealing problems using Aerospace Technology.
Installation Notes
The graphite foil sealing inserts can be replaced in the aluminum retainer, making it an economical solution to tough sealing problems. Replace the seals on a smooth flat surface using even pressure for best results.
Features
Uses Aerospace Technology
Reusable/Adaptable
Graphite Foil Sealing Inserts
Virtually Leakproof
Seals Up To 1200% Better
Superior Torque Retention
Longer Lasting Pre-Load
90% Break Loose Torque"
Dave
Irelands child
