Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Header gasket/collector gaskets
Old 11-21-2006, 03:26 PM
poncho62's Avatar
poncho62 poncho62 is offline
Wiki Edits: 5
Just like johnsongrass1, I use the stock metal backed ones that you get in gasket sets. I have found over the years, that its more the bolts you use and how you tighten them more than what gaskets you use. When installing new gaskets, check for tightness the 1st few times you heat the engine.
