header gasket help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2012, 09:22 PM
header gasket help
I am installing my Herman headers tomorrow on my profiler heads. My question is the exhaust ports are d shaped and the primaries are oval shaped. Should I use the gaskets which came with the headers which will partially be in the exhaust path or should I get a set of gaskets that are the same size as the exhaust port
Old 05-30-2012, 10:12 PM
327NUT's Avatar
Honestly....you should have gotten a set of headers that fit your exhaust ports but I would use the D port gaskets.
Old 05-31-2012, 07:46 AM
The port and the header primary are the same size just not exactly the same shape on the bottom of the primary tube
what is the best header gasket???? kuhn-77 Engine 18 12-01-2006 04:53 PM
header gasket 49dream Engine 1 04-15-2006 06:20 PM
Best header gasket? Trav Engine 4 10-05-2003 12:30 PM
header to pipe gasket. uniques67 Engine 1 06-21-2003 12:03 AM
Header Gasket 66chevy2ss Engine 13 09-13-2002 09:02 PM
