Which header gasket should I use on my vortec 062 heads?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2011, 01:26 PM
redfish211's Avatar
Hey All,
I recently purchased a set of hedman headers from summit :http://www.summitracing.com/parts/HED-69090
Now I am looking to purchase the right cooper gasket to get the correct seal. The problem is that the exhaust ports are not completly circle or square...so this is why I need help selecting the right fit for the vortec heads. These are the gaskets I have in mind:
http://www.summitracing.com/parts/SUM-111405/
http://www.summitracing.com/parts/SUM-111406/
So which one should I use for the correct seal??
Thanks!
Old 07-12-2011, 02:03 PM
Banned
just use a stock gasket or high temp sealant.
Old 07-12-2011, 08:38 PM
Pennsy86monteSSGuy's Avatar
Another Old Gear Head
I just used stock Fel-Pro gaskets on mine and they work just fine, no leaks at all.
what is the best header gasket? kuhn-77 Hotrodding Basics 27 02-18-2014 09:33 AM
header gasket 49dream Engine 1 04-15-2006 06:20 PM
header gasket Q&A chevelle_502 Engine 7 10-01-2004 07:23 PM
best header gasket for BBC? 79454 Engine 9 01-03-2004 08:23 PM
Best header gasket? Trav Engine 4 10-05-2003 12:30 PM
