Header Gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2007, 07:06 AM
Header Gaskets
Looking for header gasket advice. What would be best. Is copper good? Looking for the best to avoid leaks. It is a SBC with world CI heads.
Old 06-11-2007, 12:20 PM
Wiki Edits: 31
factory exhaust manifold gaskets, torque evenly, then retorque after you heat them up.
Old 06-11-2007, 12:37 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I used to double-gasket my headers, and follow this sequence:
Torque.
Idle.
Torque.
Drive around town and get them quite warm.
Torque.
Take it out on the highway and drive the snot out of it.
Torque.
And then check and retorque periodically.
I think I'm going to try a set of these next time.
Old 06-11-2007, 12:42 PM
Or, you can use copper, and stage 8 fasteners. And never get a blown gasket. And never have to re-torque. I've never found anything that worked nearly as well as this combination.
Pat
Old 06-11-2007, 01:16 PM
speedydude's Avatar
Registered Cruiser
The Percy's look good. Forgive my ignorance here, Stage 8 fasteners????
Old 06-11-2007, 01:21 PM
Fasteners with a positive, anti-rotation mechanism. I think http://www.stage8.com will get you there. Expensive (so are copper gaskets) but in the final analysis, this $60.00 or so solution will not leak. For me, everything else I've tried has failed. I decided failure was no longer an option, after at least 3 gasket change-outs on one car.
Pat
Old 06-11-2007, 01:35 PM
speedydude's Avatar
Registered Cruiser
Thanks for the tip. Sounds good. I'm always listening to the header gaskets whenever I pop the hood. Man it would be nice to put something on that really works and forget about it. I'm running stock gaskets, heated then retightened. So far, so good but I'm sure eventually they'll go the way of the rest.
Funny....I was thinking the other day about safety wire for the bolts but could not figure out how to make it look good with my header setup. We used these on aircraft all the time but stuff was set-up for it.
My new linkage from Jegs just arrived so I'm outta here!
Old 06-11-2007, 02:33 PM
I have excellent luck using stock manifold gaskets with nothing between the gasket and block but a bead of high heat copper RTV where the header seal bead is located. Check for tightness now and then after initial mounting.
Old 06-11-2007, 02:50 PM
use the Victor Nitroseal gaskets. Lay a thin bead of ultra copper around both sides of the port. Let skin (approx 30 min) Install & check/retorque as necessary for the first few days. No Worries.
Old 06-11-2007, 04:21 PM
Last journal entry: car is painted
The fel pro gaskets work great as long as your header flanges are decent.
Old 06-11-2007, 04:28 PM
One of my header bolts some how got snapped off in the head, probably before I got it. I doubled up a pair of Percy's aluminum gaskets and haven't had a problem yet. Ive re torqued a few times since then. They were a little pricey though, I think something like $35-$40.
Old 06-11-2007, 08:04 PM
DoubleVision's Avatar
I ran stock exhaust manifold gaskets on my cutlass for years. the fel pro repops are mesh steel and resist burn out. Recheck the tightness a time or two and no more worrys.
Old 06-11-2007, 08:38 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
I have a 351w with World heads, I tried copper gaskets but they started
leaking, so I picked up a set of Aluminum gaskets & wire lock header bolts, &
so far have had no leaks, 4 months & I don't know how many miles.
Good luck,
rich
header gaskets markzepp820 Engine 5 12-14-2006 05:42 PM
Header gasket/collector gaskets Jmark Engine 9 11-21-2006 03:13 PM
Smallblock Header Gaskets boss350 Engine 12 07-09-2006 10:16 AM
sloppy header gaskets :-( Vortech 4.3 Engine 1 01-15-2006 10:00 AM
Header Gaskets dollybud Engine 5 06-02-2003 08:38 PM
