header gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2009, 07:11 PM
header gaskets
Should I Change The Factory Header Gaskets On Headman Headers Before I Put The Inner Finders On My 1951 Ford Fi With A 383 Stroker?
Old 09-21-2009, 07:30 PM
thomaseh
2 years ago I put on Pacesetter Headers and used silicone on both sides of the gaskets as recommended. I only got 2000 kms of use before one blew and they were re-tightened as required from the beginning.
I then ordered the cardboard type gasket that Pacesetter sells, soaked them in warm water for 30 minutes, then installed them on bare surfaces without silicone. I have since gotten over 20,000 kms and no problems since. Best job I`ve done yet, if this helps.
Regards,
Tom.
Old 09-22-2009, 10:59 AM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
I tossed my set of hedman shorty headers in the swap meet pile after I got tired of the flange torquing on me. Could not understand why they did not use 3/8 flanges on those.
On the knock-off replacements I used the stock style three piece exhaust manifold gaskets. These come in the Fle-Pro rebuild gasket kit. They are the aluminum looking perforated pieces. The part number is MS9275B.
So far I have not had any issues with these. A lot cheaper than some of the other options and simple to install.
header gaskets markzepp820 Engine 5 12-14-2006 05:42 PM
Header gasket/collector gaskets Jmark Engine 9 11-21-2006 03:13 PM
Smallblock Header Gaskets boss350 Engine 12 07-09-2006 10:16 AM
sloppy header gaskets :-( Vortech 4.3 Engine 1 01-15-2006 10:00 AM
Header Gaskets dollybud Engine 5 06-02-2003 08:38 PM
