Header Gaskets
What is the best heater Gaskets For Finder wlll headers with Plates, it burning thru in the center flange. I am running methnane or alcohal as fule.
Douglas Ray |
Bogie |
| The Following User Says Thank You to oldbogie For This Useful Post: | ||
thinwhiteduke (02-21-2013) | ||
I did some searching here on the Hot Rodders site a while back looking for header gasket recommendations and found this thread: how do you pick header gaskets for SBC
That lead my to use stock manifold gaskets on my headers. If you are running stock heads, with stock port configurations, they work just fine right out of the box. Not sure though how they will work with the fuels you are using. Here's the gasket set P/N's I ended up using: ![]() Gaskets installed:
Last edited by lakeroadster; 02-21-2013 at 04:26 PM. Reason: Kant Shpell two guud |
| header gaskets | 69 gto | Hotrodding Basics | 1 | 03-11-2012 10:50 PM |
| HEADER gaskets! | ONECUSTOM73 | Engine | 8 | 04-19-2010 02:50 PM |
| the best header gaskets to use????? | dannyessexc | Engine | 8 | 05-15-2009 04:02 PM |
| header gaskets | markzepp820 | Engine | 5 | 12-14-2006 05:42 PM |
| Header Gaskets | dollybud | Engine | 5 | 06-02-2003 08:38 PM |
