Yes on the burning valves, the metalic gaskets with screen inbetween the layers are some of the best to use. Never had one go bad yet.
Luv the smell of NITRO in the morning. |
HEY DOLLY: I have tried every header gasket and bolts known to present day man on headers.
I have found that the soft metal on fiberboard, which are about $ 10.00 at NAPA work the best. Copper won't seal on a warped header flange no matter how tight you force the bolts. They are expensive and I have a whole box of them that never worked longer than a week. Mr Gasket also makes a good inexpensive header gasket. There should be info on their web site. Another tip I saw said to use BBC gaskets on SBC headers because the shape fit the outline of the header better GOOD LUCK....DAVE
Hey guys. I used an SCE copper gasket on my BBC, and I didn't have any exhaust leaks with mine, but I've heard they don't work that well. My Uncle uses the crushable aluminum style and he's never had one, and I have a couple of friends have switched and haven't had any problems yet. I think I'm going to also on my next motor.
After buying God knows how many sets of header gaskets I finally listened to an old man in the neighborhood. I started using OEM style manifold gaskets like Victor makes M7110X and a ring of copper hi-temp silicone around the prts between the block and gasket. Gaskets installed with perforated metal face to block, composition side to header flange. I use the copper hi-temp in a ring around the gaskets on header flanges as well. Let the stuff set up per the directions before assembling and then you're there for the duration!
