Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - header leak
Thread: header leak
Old 09-25-2002, 11:57 AM
dusterbd dusterbd is offline
Hellbilly Hotrods
Post
you amy also take a trick from the same pontiac guys i stole it from. cut the flanges in between the tubes, like say between the 1 and 3, and the 5 and 7. it helps the header seal better to irregularities in the head, and also takes out some of the warp possibilites. i doubt id have any leaks if i used header gaskets and not the regular exhaust manifold gaskets.
mike
