header/manifold wrap questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2006, 11:00 AM
ok I cant afford to get my headers ceramic coated so i opted to buy some heat wrap from a buddy of mine....only thing is i dont know how to join the wrap on the pipes!? Somebody told me to use coathanger wire...that seems pretty backyardish...does anybody know the best way to wrap headers /manifolds, and how to make it tight and stay tight on the pipes?
Old 05-03-2006, 11:05 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Bailing wire or hose clamp.
Some eone sells a clip for it but I can't remember who. I know they do because it came with a package that a buddy bought a few years ago.
Old 05-03-2006, 05:09 PM
I've had very good luck with regular solid copper telephone wire, it's dead soft so you can twist tie it tight and trim it close, it does stay tight
insulation burns off in a heart beat, then it is just about invisible on the wrap
I do use hose clamps on the collectors, to much air at speed, the wrap will un-ravel
Old 05-03-2006, 06:49 PM
Header wrap manufacturers make straps just for that purpose. As an alternative we have used stainless steel safety wire for years. We twist it tight with the safety wire pliers.
Old 05-04-2006, 09:01 AM
Technical Support Barry Grant
The stainless band wraps are the best, and look the cleanest, but I too normally use safety wire.
Old 05-07-2006, 04:07 AM
malc's Avatar
Living At The Speed Of Life
I used header wrap despite the manufacturer stating not to.
Luckily I took it off in time, it tends to attract moisture and rust the headers.
I just had a few holes to get welded up.
I do live in a humid part of the world and the car was not used daily to heat off the moisture.
Old 05-07-2006, 05:26 AM
malc,
fair to very good chance moisture had very little to do with the pin holes...
you burned the pipes from inside,
due to the exhaust temp "exceeding the pipes mfgr allowed max temp".....
that's why they said don't wrap them...
incase you do have wicked hot exhaust temp's
yes, the wrap traps (more) heat in the headers, yes the pipes are hotter wrapped....that's what you want for more exhaust scavaging to gain HP/tq
nah, you can't match central Florida for wet!
wrapped my $99 headers to keep heat out of car,
they were fine after 8yrs (?) of relatively normal exhaust temp
Two questions about a BBC RObs71Nova Engine 10 07-03-2012 03:55 PM
ANSWERS TO COMMON QUESTIONS -- PLEASE READ BEFORE POSTING Jon Hotrodders Site Suggestions and Help 0 07-07-2005 04:58 PM
Suspension-Brakes-Steering Common Questions Jon Suspension - Brakes - Steering 0 10-16-2003 04:19 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 03:01 PM
Nuts, Bolts and stripping questions Bluepen Body - Exterior 5 08-14-2003 06:15 PM
