Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 10-31-2009, 12:44 AM
diamond mike's Avatar
diamond mike diamond mike is offline
throw me under the bus agian
header paint
have any of you guys used BBQ paint on old headers before? whats good?
  #2
Old 10-31-2009, 03:37 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Socially Unsociable
Every type of coating I`ve used rusted off in weeks. If the headers are new you must sand them down or have them blasted, then use a degreaser or wax remover to make sure they are spotlessly clean. Eastwood coatings carries a coating that applies with a brush that is said to work great and looks nice too.
Old 10-31-2009, 06:00 AM
sunsetdart sunsetdart is offline
Eastwood paint will burn off....been there, done that. I have never seen ANY type of header paint that will NOT burn off. Even the hi-temp powdercoating that eastwood has does burn off. Don't waste your time and money on paint.
Your best bet is to have them ceramic coated, like Jet-Hot, if you want them to look good and stay that way
Old 10-31-2009, 06:23 AM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Only paint I've seen have any success at all is John Deere Muffler Black. It will last ONE complete summer intact if applied to blasted clean headers but will rust over the winter if not in a climate controlled area.
The only thing that is durable for longer is a Metallic-Ceramic coating like Nitroplate, Jet-Hot, or Q.C. Coatings.
Old 10-31-2009, 08:49 AM
Socially Unsociable
I have a set of Hooker super comp headers jet hot coated and they`re rusty. They don`t have 2000 miles on them.
Old 10-31-2009, 09:21 AM
damn, maybe i should just wrap them, but then i heard moisture gets in that stuff and speeds up the rust, oh well, at least headers arnt super expensive-gotta get to work, mike
Old 10-31-2009, 09:34 AM
Guy Hiltz's Avatar
Guy Hiltz Guy Hiltz is offline
Tremclad makes a brush on high heat paint,and its the best stuff that I used.It needs to be very thouroughly mixed for use.Heres a link;
http://www.rustoleum.ca/CBGProduct.asp?pid=194
Guy
Old 10-31-2009, 06:18 PM
ericnova72's Avatar
More for Less Racer
Double, did you buy them from Hooker with the coating already on them or buy them bare and ship them to Jet-Hot for coating?? I made the mistake of buying Hedman's pre-coated and they started rusting before the year was out, friends Hookers did the same thing. Sent the Hookers to Jet-Hot to be re-done and they are perfect 4 years later. The coating most of the header makers use is NOT up to Jet-Hot quality standards, it seems to just be a hi-heat powder coat and not a Metallic-Ceramic coating.
I'll never buy a header company coated header again, I buy them bare and send them out for the correct coating.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "header paint"
ThreadThread StarterForumRepliesLast Post
6 layers of paintstu_yoakamBody - Exterior710-06-2009 11:10 PM
Paint question for the expertsKevin45Body - Exterior3402-23-2009 06:03 PM
wax and grease removeradrock430Body - Exterior1407-30-2006 01:18 PM
This is interesting. Temporary peel off paint.kenseth17Body - Exterior508-11-2005 10:41 PM
Change colour high temp header / turbo paint?SyclonedBody - Exterior108-03-2003 10:08 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
