Header question - small primary tubes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2012, 06:10 PM
Gearhead forever's Avatar
I'm looking at a set of cheap SBC headers from a local guy but the primary tubes look too small to me. (1-1/2", not 1-5/8" with a 2-3/4" collector) The ports also look too oval also - I thought SBC ports were more rectangular with heavily radiused corners. (Dont have a set of heads to compare)
I need them to fit a stock '95 5.7 which will get vortec heads eventually. He claims they are for an '81 chev c/k truck.
any thoughts?
Old 06-20-2012, 07:34 PM
Actually a pretty good size for stock heads even stock vortecs.
Old 06-24-2012, 09:47 AM
ok, thanks. - would they be adequate if I built a 383 stroker?
Old 06-24-2012, 10:26 AM
vinniekq2's Avatar
headers
I had my headers custom made by jerestahl, these people are friendly and extremely knowledgeable.Header tube size and length is very important for powerful engines.Think of headers the same way you think about intake manifolds,most all of them are an improvement over stock.Beware not to buy too big of a primary pipe header as this will not work well with a mild engine. One header is never perfect for every engine.
This is not an answer but it does help you ask a more defined question when you build a bigger engine.Small tube headers are good for stock engines for now.
Old 06-24-2012, 10:43 AM
thanks, thats what I really needed to know
chevy 406 - pass header tubes hot gilby246 Engine 14 05-17-2009 09:50 PM
Header Primary Tube Sizes? 406chevycaprice Engine 7 02-12-2008 09:04 AM
Header tubes glowing rolrandy Engine 26 12-18-2007 11:55 AM
header primary tube advice ucmung Engine 16 12-06-2006 11:52 PM
are 1 5/8 long tubes too small for a 414 ci small block? tony350ss Engine 8 03-17-2003 12:45 PM
