Header Repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2002, 11:14 PM
New Member
Post Header Repair
I've got a set of 180 degree, "bundle-of-snakes" headers on a SB Ford. At some point some pin-holes in the under side of a couple of the tubes was repaired by brazing. My question is: will this hold up, or will the exhaust end up melting the braze. The repairs are within an inch or two of the exhaust port.
Thanks,
John
Old 11-01-2002, 04:00 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
No problem. Brazing will take more heat than your exhaust will ever generate. I always run a bead of brazing on headers I build around the outside of the header flange where the tubes enter the flange. I do this for appearance and to prevent any leaks or corrosion that might otherwise happen in this crevis.
Old 11-01-2002, 10:34 AM
New Member
Post
Thanks for the reply- i'll breathe easier!
John
