Header size question for engine on budget? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2006, 11:40 AM
84Z 84Z is offline
Gas Raper
My engine has about 600 to the crank at 6400, and I'm goign to spray another 300 through that. I wanted to get some hooker super competition long tube (1 3/4" primary, 3" collector) but with my budget, I can't really afford those. If I were to go with hedman long tube headers (1 5/8" primary, 3" collector), which are a couple hundred cheaper, how bad would the hit be to my power? Would I be better up saving for a few months to get the super comps? I need to get other stuff for my car as well, so all the money I can save would help very much, but then again if it'll kill my power significantly, then I'll rethink it. What do you guys think, thanks.
Old 01-23-2006, 12:08 PM
How did you arrive at the 600 figure without headers? It's hard to dyno an engine without them.
Old 01-23-2006, 12:09 PM
1 5/8 will crush your power if you are in fact making 600 to the crank. I would estimate 50-100 HP and a ton of torque as well. Spraying 300 on top of this I would be looking at 1 7/8 or 2" with around a 32" long tube.
Old 01-23-2006, 12:19 PM
84Z 84Z is offline
Gas Raper
Bought the engine from someone and he provided the dyno sheet
Old 01-23-2006, 12:28 PM
Last journal entry: PICTURE TEST
headers
save the money and buy the correct headers...
Keith
Old 01-23-2006, 01:14 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
How could you afford to buy this engine, but cant afford the headers? Sounds like if the engine makes 600 HP and can take a spray of 300 HP it must have cost a good amount to build and or buy.
Old 01-23-2006, 02:12 PM
What size are the exhaust valves?
Old 01-23-2006, 04:08 PM
84Z 84Z is offline
Gas Raper
I'm college and worked all summer for it.. Can't work now so I have no income, just old parts to sell.
Old 01-23-2006, 04:09 PM
84Z 84Z is offline
Gas Raper
Brodix track 1 heads, 1.6" exhaust
Old 01-23-2006, 04:54 PM
johnsongrass1's Avatar
Race it, Don't rice it!
I'd like know how those heads can support 600hp?
Even with 17:1 CR I couldn't do it. We used to roll them over .150 to straighten the intake angle and couldn't do it then either.
Are you sure somone hasn't playing with the dyno?
Can you post your sheet?
I'm just curious really?
Old 01-23-2006, 05:01 PM
84Z 84Z is offline
Gas Raper
The dyno sheets at my house, but I did see the engine run on the dyno and it went 597 at 6400, that was with a small blower that started choking the engine, another dyno run wasnt made when the blower was removed. I seriously doubt the blower helped much, wasnt running much psi due to compression and as I said it was small. I just use the numbers because it's the only thing I have to go on, and with a matter like this, it's better to over estimate then under.
Old 01-23-2006, 05:34 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
I would save up for the super comps. You will just be throwing your money away if you buy the 1 5/8. And hurting the engine rather than helping.
Header Gasket Question Toyguyz Engine 12 03-15-2003 09:37 PM
header question. 1 5/8 long tube or 1 3/4 shorty??? tony350ss Engine 1 02-20-2003 02:40 PM
Chevy/GMC truck header question? dirtlmfan Engine 1 01-28-2003 12:29 PM
open header question HotRod63 Engine 6 12-21-2002 06:07 PM
Header question awsum34 Engine 0 11-12-2002 01:50 PM
