header tube temp - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2011, 01:02 PM
header tube temp
Is this something I need to look in to? My header tube temps are varying. This is the temps 1-400' 3-450' 5-600' 7-330 2-325' 4-470' 6-500' 8-520'
Old 07-31-2011, 02:31 PM
Last wiki edit: Removing stuck fasteners
header tube temps
If I did anything, I'd check my valve adjustment. Seems like a looser adjustment would decrease fuel vol. and cause a cooler tube.
I know my old dun-toff cam solid) called for 20 and 20, but I ran them on 12 and 20 and got a better time, can't remember the diff. cause that was 45 yrs. ago.
Old 07-31-2011, 02:52 PM
I think. Your wright I went back and read the info on my heads (eld e-tec 200) I think I need longer push rods I'm not real sure I used comp high energy roller rockers . They said to use .100 longer with stock rockers. I had to set the valves at 0 if I turned them qtr turn more the valves would open I new something wasnt wright but I have never had a hyd. Rollercam before . I was told it would be fine . Guess not.
Old 07-31-2011, 05:18 PM
Pantaz's Avatar
How are you measuring the temperatures?
Old 07-31-2011, 05:45 PM
Lazer gun . I may have more trouble I looked up my camshaft its a Gm 10185071 hyd roller .they don't offer it for a 1997 . But it ln there .
Old 07-31-2011, 09:26 PM
Pantaz's Avatar
Originally Posted by louis165
Lazer gun .
That would be a non-contact infrared thermometer.
Among other variables, the measured temperatures are influenced by the location where you point the thermometer. Also, since it's measuring the surface of the tube, air flow might be cooling some areas more than others.
When comparing measurements, make sure you duplicate conditions as closely as possible -- same RPM, same engine temperature, aim the laser at the same locations.
Old 07-31-2011, 09:39 PM
I tried to get as close as I could I think its going to be valves I was only able to set them at zero lash I had a guy tell me I needed longer push rods he checked them and said they needed to be 56 thousands longer I havnt seen any there all a hundredth thousandths longer?
Header temp redneckhotrods Engine 12 12-19-2008 06:13 PM
Header Tube Size - S10 V8 Conversion S10 Racer Engine 1 07-13-2008 10:38 AM
Header Primary Tube Sizes? 406chevycaprice Engine 7 02-12-2008 08:04 AM
header primary tube advice ucmung Engine 16 12-06-2006 10:52 PM
Glowing header tube danbo Engine 2 12-14-2005 10:39 PM
