Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - header wrap on starter
Old 04-27-2010, 10:19 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Try this first. Run the ground from the battery to the block, and another ground from block to the trucks frame. Another small ground from firewall to engine. The headers I used in my 86 olds cutlass was for a f body car, so the header tube rode right on the starter itself. I had the same problem until I improved the grounds. After that I never had another hot start problem. The benefit was the electrical system worked alot better afterwards. It killed 8 starters before I wisely improved the grounds.
