Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - header wrap on starter
Old 04-28-2010, 12:15 AM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
There are also reflective foil-coated starter blankets made of a similar material as the header wrap but with a layer of foil on rthe outside to reflect the heat away.
Moroso also sells a nice double-walled with internal heat material metal shield which bolts to the starter that works well also.
MAD Electrical sells a Hot Start kit that adapts the better Ford solenoid to GM applications, this helps a ton also.
