Headers for 1938 Chevy Coupe.......Suggestions? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2013, 09:02 PM
I have 1938 Chevy coupe with a 350 in it and would like to install some headers. My issue is that I don't have much room between the engine and frame and if I get headers that will not fit, I just wasted money. Anyone here with a chevy around the same year with a Chevy 350 and headers? If so, what headers did you install? Basically, I don't want to buy something that doesn't fit.
Thanks
Willy
Old 01-06-2013, 09:07 PM
Thanks
Willy
Depends on what front clip is in it, mines a 40, with a nova front, running long tubes for the doner car and have no issues.
But if your not looking for big HP gain, then block huggers will almost always fit.
Old 01-07-2013, 01:32 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Fenderwell headers.....
Old 01-07-2013, 11:44 AM
Last journal entry: No Progress
I have a 38 sedan with a Mustang II type front suspension and use some block huggers from Ebay. Fit with no problem.
Old 01-07-2013, 01:09 PM
spacytracy's Avatar
Last journal entry: New neon sign for the garage
Block hugger headers fit with plenty of room
Old 01-07-2013, 06:03 PM
Thanks for the input. I also have a mustang II front suspension
Old 01-07-2013, 06:04 PM
You do mean the shorty Huggers.... Right?
Old 01-07-2013, 06:37 PM
I have a 1937 Chevy pick up. I bought a set of long tubes designed to fit a SBC in a model A chassis. I think they were from Patriot, but couldn't say for sure.
Pat
Old 01-08-2013, 12:31 PM
spacytracy's Avatar
Don't know if shorty is the correct term. I used Patriot ceramic coated hugger headers that dump straight down to the exhaust. My car is low enough that shorty headers would not clear the ground as the collector would be under the car. 2 1/2" exhaust pipe with Flow master 40 mufflers
Old 01-08-2013, 02:51 PM
Senior Curmudgeon
Wiki Edits: 326
Fenderwell headers.......
Old 01-08-2013, 03:39 PM
Headers
Why headers, I have a warmed up 350 in my 48 Chevy with a mustang II front suspension. Unless you are building a race car manifolds work fine, don't leak and clear late model Gm steering. I don't think my engine has ever seen any rpm over 5500 so all headers would do is make noise, of course I'm an old man and like to cruse and stomp on it once in awhile and the car is fast enough for me. LOL.
Old 01-08-2013, 04:00 PM
I bought a set of stainless steel block huggers from Speedway, cheap!
1938 chevrolet coupe chopped 3" spacytracy Introduce Yourself 1 11-09-2010 03:07 PM
1938 chevrolet coupe chopped 3" spacytracy Hotrodding Basics 0 11-09-2010 09:53 AM
1938 Pontiac Coupe dnkvette Suspension - Brakes - Steering 7 02-04-2010 10:19 PM
1938 Pontiac Sport Coupe rchrischris38 Introduce Yourself 15 05-28-2008 06:01 AM
1938 plymouth buisnessman coupe redlineharleys Interior 4 01-09-2007 02:38 PM
