Headers for a 1967 El Camino - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2010, 11:55 PM
Last journal entry: Dual 13 inch fan install
Hi y'all. I'm in the process of installing a new hyd. roller cam (comp cam: XR264HR) along with a Weiand 8019 and Holley 750.
I was wondering if the Headman Headers 68190 would be a good match for this? Right now there is just the stock exhaust manifolds.
Thank you.
Oh yeah. Are Locking Header Bolts something I should pick up if I get the headers?
Old 04-29-2010, 09:59 AM
Last journal entry: 50 Ply wagon
If this is a streeter then using any brand name header will be fine. Hedman is a good one and should work fine with your combination. Locking bolts are a good idea as well, but I found using some hi-temp silicone on the threads holds the bolts tight and they can be taken out with no problems.
Old 04-29-2010, 10:12 AM
Cool. thank you for the silicone tip!
Hello El Camino zoomer56 Introduce Yourself 4 09-17-2009 09:36 PM
el camino drop spindles 1979 Camino Suspension - Brakes - Steering 5 08-31-2008 05:04 PM
Chevelle or El Camino Addicted2Gas Body - Exterior 5 08-18-2008 11:16 PM
64 el camino brake conversion camino_man Suspension - Brakes - Steering 0 01-30-2004 06:01 PM
Hookerk Super Comp Headers fit me el camino? Echofive Engine 1 01-24-2004 10:40 PM
