headers 59 t-bird w fe motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2011, 10:21 PM
Last journal entry: 59' T-Bird
Looking for headers that could fit my 59 T-bird. Not sure if 60's era Galaxy units would work. Wanted to see if anyone has any info or worked with one of these square-birds?
Old 10-22-2011, 12:21 PM
Try these guys http://www.fordpowertrain.com/FPAindex/headers1.htm
assuming this is the FE 352 not the MEL 430.
1961 and up will not work, the car was widened that year; headers that fit those chassis have turns that are too generous to fit the 1958-60 bird.
Bogie
Old 10-22-2011, 02:18 PM
59 T-bird Headers
Thanks for the link, looks like they have what I need. Yes, I am running the 352 at this time but may change out to a 390 with a C-6. Do you happen to know if the C-6's larger size will create any clearance issues.
Old 12-22-2011, 06:15 PM
I found the perfect headers, not sure if you can find some but these work.
I found the perfect headers, not sure if you can find some but these work on my 58.
ID:	61030   Click image for larger version
Old 12-23-2011, 07:12 AM
59' Squarebird
Looks great, I think I'm going to proceed in the same fashion. I've run across a nice 390 mirror block and a 428 crank, .030 overbore should give me a 416. Are you running a C-6, if so any issues in bolting it up. I'm reworking the suspension now (new springs , shocks, control arm bushings etc), and have been taking a hard look at putting a power rack in the front end.
Old 12-23-2011, 11:36 AM
custom trany behind my 406
Over the years as the HP went up I learned a lot about the cruise-o. I know there reputation isn't the best but like most things they can be improved on with good old fashion hot rodding. Clutches can be modernized. A little work on the front servo (gut it) and she catches 2nd just right (the most important shift). There is a little magic to the governor to match engine torque. No bull **** vacuum shifts. And last but not least MAINTENANCE....I have a factory pressure line plumbed to the back of the intake (see it in photo2), how often do you check your trany pressure? Don't forget the linkage, I love being able to dial in the mood with one nut.
It's stock and it works.....
Some might think I'm crazy but isn't this what hot rodding is all about.
ID:	61035   Click image for larger version
64 t-bird lookin for smaller gearbox and headers thunderbird6412345 Suspension - Brakes - Steering 0 02-09-2011 04:59 PM
Headers 4 a 62T-bird? Clos & his 62 T-bird Engine 2 11-20-2010 08:03 PM
motor for my bird v6bird Transmission - Rearend 2 10-10-2003 09:58 PM
1964 T-Bird motor ID hjimz Engine 1 12-17-2001 11:48 PM
