headers with angle head plugs?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2012, 02:01 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hello
I got edelbrock rpm heads with angle plugs. Angle plug shortly headers are pricey. If i use regular shortly headers and the shortly spark plugs think i could get away with it? Tnx hg
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 03-04-2012, 03:55 PM
DoubleVision's Avatar
You've got me a little confused Hemmie. Angle plug heads are angled to make changing plugs easier. I've never heard of angle plug headers.
Old 03-04-2012, 08:12 PM
Yea a lot of headers say will not work with angle plug heads. I guess cause it angles the plug to close to the header pipe. I just wonder ifi use shifty plugs if it will matter. Or do i spend another 50 bucks and buy the ones designed specially for angle plug heads?? Nf
Old 03-04-2012, 09:19 PM
327NUT's Avatar
Heres my 331" sbc with Sanderson "CC5" shorty's and Edelbrock straight plug heads. I had no problems with my Taylor wires so the angle plug heads should work even better.
Old 03-05-2012, 08:24 AM
Kool. Tnx for the info. HG
Old 03-05-2012, 02:23 PM
Some headers will clear angle plugs usually simpler designs that use center dumps. When you get into more complex designs whether short or long tubes you can run into problems. Rest assured that when the manufacturer says they don't fit angle plug heads, you can take it to the bank, they don't fit angle plug heads.
This leaves you with either buying headers you know don't fit and betting that short plugs and or beating dents in the tubes will get you by or spending the bigger bucks to buy headers that will fit angle plugs.
By the way, angle plugs were not developed to clear headers, it has everything to do with changing where the ignition point occurs in the combustion chamber to improve power output, which it turns out is also good for emissions reduction, it has nothing to do with header fitment and often makes headers a lot more difficult, if not nearly impossible to fit ala GT40P heads on a Mustang.
Bogie
882 heads with angle plugs?? joeyb Engine 24 09-29-2009 08:59 PM
Help ID if SBC heads are straight or angle plugs y2k600f4 Engine 2 09-25-2008 11:29 AM
Strait or Angle Plugs 70bird Engine 6 07-08-2008 09:03 AM
Uggggg. Why angle plugs??? Blue68Camaro Engine 12 10-19-2007 08:45 PM
Straight / Angle plugs what is the difference ? terror385 Engine 7 12-02-2003 12:00 AM
