Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Headers burning up my starter!
  #25 (permalink)
Old 11-20-2012, 01:22 PM
ChevroletSS ChevroletSS is offline
Be very careful I actually had this same problem in my truck where the exhaust manifold was touching the starter wire and it cought on fire. Had to use a fire extinguisher to put it out. Since you have a custom header I dont know but see if you can reloacte how the starter wire is coming to the starter. It helps to get under the vehicle. You can see more. If not I would try to make an aluminum heat sheild.
