I have very large, tuned pipe headers on my BB Chevelle wagon. They are eating up starters and burning my cables. The headers don't go down through the normal place at the back of the engine, they twist and bend down the side of the engine and one pipe wraps right around and under the starter, burning the cables and solenoid constantly. The starters last about 4 months Max! Even heat wrapped.
Has anyone built heat sheilds for these? Are they effective? What should they be made of? As a last resort I would install normal headers to stop the problem, but I don't want to risk affecting the performance of the engine.
I'd think you could fab up a system like g.m. did for the poor carb'd t/a's
a thermo switched fan to blow on the starter area when stut off (heat soak )and a simple pipe to direct air to the starter while car is moving..
g.m. did something like this on the 85+ pontiac t/a to keep the fuel from boiling in the carb..
a small fan and a thermo switch thats only ativated when car is off. would cool the starter and header
when moving you'd have something like a brake duct on a race car.. to cool that area.. just the air movement alone will help..
I've built shields from thin aluminum sheet that easily cut and bent. Also some header wrap to the closest tubes to insulate the heat from getting to the shield.
Exactly. Using two or more pieces together and leaving an air gap of maybe 1/8" between the pieces by using flat washers as spacers works well. I have never seen the fan arrangement, but it makes a lot of sense to me.
Probably not running lean, plugs look fine. It's a 541 inch roller motor putting out about 700hp. The header tubes are 2.5 inch and tuned. The tubes don't go back toward the firewall then down where they are supposed to. They go down and twist around right under the engine. One of them wraps right around and under the freekin starter. I will attach pics when I het home today.
Wow, for 700hp I'd be willing to replace a starter now and then :-D Plus, it being in a wagon makes it even cooler (to me, anyways).
I know folks have used the multi-layered cookie sheets to make heat shields with. That, plus a silica fabric or reflective wrap ought to help.
Is the routing of those headers something that was done to have them properly tuned?
Good luck, I hope you straighten it out. If not- I hope you buy the lifetime warranty starter, so at least ya don't have to pay for it each swap!
If its any consolation....its a common problem on BB Chevs...Are you using a stock sized starter or a mini starter? Mini starter would get it further away from the pipes
Have had the same problem with big headers on big blocks and on all of them just switched to a good brand mini starter and wrapped them and no more problems after that.
Yes I already have a mini starter, I bought a lifetime unit so that's not a worry. A standard starter will not even fit in the space. The headers were hand built to only fit a mini starter. The process of removing it is horrible though. I cannot get to the bolts. It has an offset bolt pattern unlike a standard BBC and the offset bolt is right under the number 8 header pipe. I have to use a freekin open end wrench to get the bolt out. The exhaust also has to be dropped off and the passenger header has to be removed and pulled out of the way to access the starter bolts. The header cannot come out though, they had to be laid in the frame before the engine was lowered in, but I can move it just enough to get the bolts out. Then it takes about 15 minutes to work the starter out of it’s spot. I hate it! The whole starter takes me 10 hours of work to swap.
That Moroso heat shield looks like that way to go. Heat shield + starter wrap + header tube wrap might solve the problem and for hundreds less than new headers.. All good ideas, thanks to everyone. I have never run into this problem before.
Lumberjack said it would be worth the 700 horsepower, it is.:evil: When the starter is working, it’s crazy fast, most out of control thing I have ever driven. People are shocked when they see a big station wagon. But if I don’t fix this problem, I will end up stranded somewhere.
I totally agree with your feelings on big HP vs. reliability. It doesn't really matter if you have 2,000 hp, if it wont start. Hope you get it reliable so you can enjoy it.
I have a big block with the same issues. And I'm not even running large primary tubes. I'm running Hooker Comp headers, and they snake around the starter. Takes me all day to change my starter. I have to pull the dipstick tube, the tranny cooler lines, the plugs and wires on that side, and remove the header. Then I have to remove the heat wrap, so I can SEE the starter. Last starter I put in it lasted 6 months. I'm going to buy a better starter next time, and put more Thermo-Tec wrap on the tubes. It has some on there now, but it could use more. BB race motors eat starters.
I had the same experience with a new 496, would not start when hot. Put three new (rebuilt) units in with same result. Installed a Ford Selonid on fairwall to run full battery power to starter, haven't had a problem since. I was not convenced this would work but it did.
I had the same experience with a new 496, would not start when hot. Put three new (rebuilt) units in with same result. Installed a Ford Selonid on firewall to run full battery power to starter, haven't had a problem since. I was not convenced this would work but it did.
Wow. I need to give this a try. I wouldn't think it would work either, but I would be willing to give it a shot! Easy enough to do.
Problem could be the solenoid on the starter. It's in the heat too.
Remote mounted solenoid is away from the heat.
I always thought it was the starter motor itself cooking and going out.
But it could be solenoid related. We'll see. I'll try it out and see what happens. I need to figure something out. Tired of this issue.
BBC do seem to go through starters if they are high compression motors. I used to go through them all the time in my 427 when it was 11:1 cr, but once I dropped it down to 9.5:1 it literally stopped eating starters. I've had the same starter in the car for 13 yrs. now.
I have Doug Thorley headers on my '71 Camaro, and I can pull a starter and replace it wihtout moving anything. I had the first set of Doug's headers on the car from 1974 until this year, and just replaced them with another set of Doug's headers, and they fit equally well.
I have Doug Thorley headers on my '71 Camaro, and I can pull a starter and replace it without moving anything. I had the first set of Doug's headers on the car from 1974 until this year, and just replaced them with another set of Doug's headers, and they fit equally well.
These Hooker Comps I have make the power, but they are all over the place. The left side is great, but the right side header is in the way of everything.
Header wraps will retain moisture and cause the above problem. Not a huge issue on an off the shelf header; but this could be a big problem for trick, one-off, super money headers. No one mentioned a ceramic coat INSIDE and out. I think sending your headers out to be coated in and outside will push the heat farther down the pipe. This will also fight corrosive compounds that the wrap retains. However, pushing that amount of heat farther down the system may cause damage elsewhere unless addressed (Stainless downstream of the headers). And the lowest point in the system will retain moisture/ corrosive compounds, so plan for that and make it easier to remove. If you have an X pipe or Cross Over, make sure its flanged so you can work on half the system.
If you value your headers, ceramic coat both the ID and OD. Im not a 'Jet Hot' brand fan, but that's just me. Do not drop them...its ceramic and sounds like you dropped your favorite coffee mug, except it costs a LOT more to fix.
Thats the guy that used to do a lot of work on our race snowmobiles (Dyno Port inc.). I used him because he's local and I felt comfortable with his recommendations.
Lots of different opinions on this subject.
My headers were cheap. I did not wrap all of them, just the areas that are near the starter.
Much of the header on the right side is not wrapped.
It would take a long time for the wrap to damage the headers.
Takes hardly any time at all for the HEAT to damage the starter though.
:drunk:
I think my biggest problem was choosing an offset gear reduction starter.
This configuration seems to place the starter motor itself closer to the header tubes.
I have decided to just get another starter and replace it. I will go with an IN-LINE starter this time. I might even spring for a Tilton, not sure yet.
I went and picked up a replacement starter from Chucks. The old one was from Schucks so it has a lifetime warranty. I have to use a starter from a ’01 or ’02 Suburban w-BBC. That is one of the few starters with an offset bolt pattern and it is a mini high torque already, my block is a Rhear and Morrison and has the weird starter bolt configuration. It cranks my big old engine OK. I am not running very high compression, only 10:1, but there are a lot of cubes and an high lift roller cam with ridiculous valve springs which makes it a little hard to crank, but not really bad.
I ordered the aluminum Moroso heat shield and will partially wrap the header pipe that gets close to the starter. If this fails, I will sell the headers and install some Doug Thorley’s where they can run down behind the engine and not cause a problem. Project for next weekend, this weekend I will be freezing in the mountains “claiming” that I am hunting.
Be very careful I actually had this same problem in my truck where the exhaust manifold was touching the starter wire and it cought on fire. Had to use a fire extinguisher to put it out. Since you have a custom header I dont know but see if you can reloacte how the starter wire is coming to the starter. It helps to get under the vehicle. You can see more. If not I would try to make an aluminum heat sheild.
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
