header hitting steering joint
hi,i would carefully grind the steering joint,as long as you can see how much you are going to have to grind. if it looks like you will not have a safe joint (having to remove too much metal from joint) do NOT grind it. best is lift engine and dimple header pipe,first use a magic marker to mark where the dimple goes. dimple minimun necessary to clear.
Just a suggestion, if you are hitting the bottom side of the header pipe can you build a 1/2 inch spacer for your moter mounts to raise the engine enough to clear the headers, if so it would be better than denting the header or grinding the steering. I would do both moter mounts to keep the engine level.
30dee |
| Recent General Rodding Tech posts with photos |
| 77 dodge b20 van steering questions | briansansone | Suspension - Brakes - Steering | 1 | 04-13-2006 03:31 PM |
| steering on a 51 ford car | 51FordDuff | Suspension - Brakes - Steering | 1 | 04-09-2006 05:19 PM |
| steering coupler ? | 54chevrat | Suspension - Brakes - Steering | 4 | 02-21-2006 02:56 PM |
| Putting on new air bag steering wheel on a older steering collumn. | CruisingRam | Interior | 10 | 12-20-2004 03:34 AM |
| Power steering pump hitting box | tjh211 | Suspension - Brakes - Steering | 7 | 11-16-2004 04:29 PM |
