Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - headers hitting steering coupler!?
Old 06-20-2007, 06:34 PM
boatbob2 boatbob2 is offline
boatbob2
header hitting steering joint
hi,i would carefully grind the steering joint,as long as you can see how much you are going to have to grind. if it looks like you will not have a safe joint (having to remove too much metal from joint) do NOT grind it. best is lift engine and dimple header pipe,first use a magic marker to mark where the dimple goes. dimple minimun necessary to clear.
