Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - headers hitting steering coupler!?
Old 06-20-2007, 06:48 PM
30desoto's Avatar
30desoto 30desoto is offline
Dodge ain't all bad
Just a suggestion, if you are hitting the bottom side of the header pipe can you build a 1/2 inch spacer for your moter mounts to raise the engine enough to clear the headers, if so it would be better than denting the header or grinding the steering. I would do both moter mounts to keep the engine level.
30dee
