Headers no o2 sensor ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2012, 07:50 PM
If I go with headers on a 1988 350 Chevy tbi motor with the o2 sensor not be hooked up will I run into problems
Old 03-30-2012, 08:21 PM
SamCam,
Yes big trouble! Check engine light will not go out because there is no o2 signals.
Scholman
Old 03-30-2012, 08:37 PM
Wiki Edits: 31
Also be in Open loop, which on a TBI engine, is a pretty rich setting.
There are affordable direct fit headders out there to fit your truck
Custom install an 02 sensor in headers? kpcrossfire6 Engine 3 03-31-2011 05:22 PM
headers??? whats so good about headers, compaired to stock exhaust manifolds? bigno09 Hotrodding Basics 7 11-12-2009 03:34 PM
Buying New Headers; ? about O2 sensor bowhunterml Hotrodding Basics 4 01-01-2009 06:32 PM
headers-o2 sensor=problems? tbi350 Geiger General Rodding Tech 4 09-01-2008 08:33 AM
Block hugger headers vs Long tube headers sexypizzaman Engine 12 05-01-2008 01:54 PM
