The only cure is to drill and tap these heads, there is enuff material there, but you have to pull the heads to do it rite, there is no miracle cure for this, less of course you enjoy leaking backfiring,headers. Thank GM's brilliant design staff for the idea, wonder how much money they saved?
The 7K3 heads can be drilled and tapped for headers but you will also need to fabricate small spacers due to the ends of the head are offset. If this is not done the headers will not seal up properly and will leak no matter what you do. DO not try to do this with the heads on the engine, and be careful not to drill to deep as you could get into a water jacket in the head.
