headers size - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2010, 01:32 PM
headers size
hallo, i new here and i have a duster whit a 360 sb
and 1.5/8 headers now, that i wonder is the different
in hp/tq betwen what i have now and step 1.5/8-1.3/4 tubes headers ?
Old 08-05-2010, 02:41 PM
327NUT's Avatar
Howdy Duster.....maybe at EXTREMELY high rpm or with a blower motor you would see a difference but with a naturally aspirated street motor you'll never feel it. Also you could actually hurt your low end grunt with larger tubes...plus the fitment issue....not worth it.
Old 08-06-2010, 03:10 PM
thanks for your info,
The engine i going to run is a street/strip 360inch and i have : ported edel heads, rpm airgap, holley 750cfm vacuum, free flow
muffler 2.5inch and pipes, woodoo cam 60404 or xe275hl..i whant to rew to about 6000-6400rpm.
Have you a advice to even a better cam for this set up ?
Right now : 2500rpm stall,
3.21 gears/have a nice day
Old 08-06-2010, 07:21 PM
327NUT's Avatar
I would think either cam if they are close to the same specs but I like Comp Cams. The most important thing though is to change the rear end gears to a 3.70 - 3.90 for the street. With the 3.21's it will be a pig and defeat all your good equipment and money spent.....good luck
Old 08-06-2010, 07:52 PM
2bbl Holley mods....
What are some carb mods for Holleys? I've came across one where you taper the top part of the booster and the bottom also.switching to annulars helps too. What else? I don't race,have any classes,no rules.just for my car.thanks
What has been your experience with headers compaired to stock exhaust manifolds?? Jim Weeks Engine 10 10-06-2012 11:21 AM
what size headers for 454? Jason7504 Engine 15 03-26-2010 04:59 PM
Need to plug air injection holes in my headers. What size bolts? Porchev Engine 7 01-27-2006 01:36 PM
Repair holes in .. headers ??? vorgath Engine 7 01-08-2006 09:55 AM
small exhaust diameter up front and big out back?? smlblcks10 Engine 76 01-01-2004 11:24 AM
