Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Headgasket or cracked heads?
Old 05-30-2009, 02:15 AM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Before you get carried away, are you absolutely sure that it is anti-freeze on the floor and not just condensation from the mufflers after parking it from a run on a night with high humidity and cooler air temperatures? Did you do a taste test of the fluid on the floor, and/or was it sticky? Although it is slightly unpleasant, the taste test never lies.
I've seen enough water from condensation come out of tail pipes to cause two dirty watercolor "paintings" on a garage door, and water drool and splatter from tailpipes.
