headgasket & valves for E85 alcohol - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2013, 03:13 PM
what valves and head gaskets do I use on my sbc 1970 350 12.5-1 compression engine for street use. My corvette is off the drag strip and going on the street.
Old 06-13-2013, 06:51 PM
SPEED MASTERS CC's Avatar
Gaskets and valves for E-85 are same as for use with gas.
The Following User Says Thank You to SPEED MASTERS CC For This Useful Post:
pappabear48 (06-14-2013)
Old 06-13-2013, 09:25 PM
Last journal entry: New Rev wheels and BFG KDW II tires
What were you using for fuel before? Chances are with E85 you are going to need to completely overhaul your fuel system otherwise you will most likely be running lean.
Rob Mix Services build carbs especially to run on E85 or he sells kits to convert a few different carbs too.
E85carbs Home
The Following User Says Thank You to 64SS327 For This Useful Post:
Old 06-15-2013, 10:14 AM
Thumpin455's Avatar
Ask me about Ethanol
Last journal entry: 65 GTO
The only things you really need to change are in the fuel system, just like speed masters said. The additions I would suggest are a 195 to 210 thermostat so you can get the oil warm enough to keep condensation out of it, and an electric fuel pump so you are sure to keep the carb bowls full. If you are running EFI then its really easy, larger injectors and a retune and you are done.
Old 06-16-2013, 11:38 PM
techinspector1's Avatar
Wiki Edits: 326
Sounds like sorcery to me.
Elgin Industries Intake & Exhaust valves? 11echo Engine 4 05-12-2010 06:35 AM
Dual M/C for '55 Ford & Residual Valves Sweet-34 Suspension - Brakes - Steering 5 07-18-2008 06:46 AM
Residual Valves & Proportioning Valve. DrBee8457 Suspension - Brakes - Steering 6 08-17-2007 06:45 AM
Question on Aftermarket valves & machining heads unstable Engine 9 05-26-2004 08:50 AM
Headgasket ? bowtieorbust Engine 9 04-18-2004 06:20 PM
