Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 03-26-2005, 07:03 PM
S10xGN's Avatar
S10xGN S10xGN is offline
Gotta love a turbo!
Headlamp Adjustment?
Hi All,
How do the new style composite headlamps adjust? Or for that matter, how are they retained (fastened)? I'm contemplating using some '05 Chrysler 300C lamps in my '47 Ford...
TIA!
Russ
Old 03-26-2005, 07:32 PM
MARTINSR MARTINSR is offline
re: Headlamp Adjustment?
Ok Russ, first off an opinion on the headlamp swap. Unless you are making a super wild, everysquare inch modified "Sniper" type custom don't put those headlamps on a 47 Ford. If you are not doing a serious "theme" change to the car they will look terribally out of place. Don't do something stupid just to be different.
The headlamp has an adjustable reflector within it. Most will have a little bubble level to level off for height. The actual aiming system for these lights cost a grand or so for the cheapest one I have seen.
Old 03-26-2005, 08:35 PM
adtkart adtkart is offline
adtkart@aol.com
Like stated, the headlights are adjusted by the movement of the reflector. There are usually adjustment screws that have to be accessed with the headlamp in the mounted position, which usually means that you have to have access to the top or rear of the assy. The headlights are usually mounted with 4 or so mounting tabs of some type, although I am not sure of the layout of that particular lamp.
Old 03-27-2005, 11:08 AM
S10xGN's Avatar
Gotta love a turbo!
So, you are saying the lamp "module" mounts solidly and the aiming adjustments are all made from within the module?
Thanks for your opinion, Martin. Nothing solid yet, just considering... Personally, I think it would look pretty fine.
Russ
Old 03-27-2005, 12:16 PM
An interesting thought is whether the 47 Ford lights would look good on the Chrysler? That can be the answer to many swaps, there has to be SOME similarity in the two styles for it to work in most cases.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Headlamp Adjustment?"
12v incandescant headlamp nettio Electrical 3 03-07-2005 08:43 PM
Carb float adjustment Steve-0321 Engine 1 05-14-2004 12:18 AM
Valve lash adjustment, Now I'm confused? Jag Daddy Engine 5 04-15-2004 11:27 PM
lifter adjustment Deadtemple Engine 1 09-20-2003 05:57 PM
4175 Holley Float Toe adjustment 7t7buckskin Engine 2 07-24-2003 07:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
