headlight - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2013, 02:04 PM
keb keb is offline
headlight
low beams are dim high beams ok on 2003 s-10 what could be wrong?
Old 02-19-2013, 02:50 PM
Headlights
Try replacing one of your bulbs and see if theres a difference
Old 02-19-2013, 02:51 PM
poncho62's Avatar
Wiki Edits: 5
Check your grounds
Ontario Rodders
Old 02-19-2013, 03:14 PM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by poncho62 View Post
Check your grounds
This X 2
Also check the power feeds
Chet
Old 02-19-2013, 03:41 PM
headlights
I wouldn't think it would be your ground. Your high beams would be dim as well. Possibly the power feed for the dims. Seperate feed for dims and highs.
Old 02-19-2013, 04:08 PM
T-bucket23's Avatar
Wiki Edits: 26
Most likely the lights are turned on by making the ground through a relay. This is fairly common.
Chet
Old 02-19-2013, 07:58 PM
EOD Guy's Avatar
If possible swap the low beam feeds with the high beams..... if you get the same issue...... as suggested check your relay feed
headlight realays elcaminodragster Electrical 16 04-15-2008 07:30 PM
headlight switch 71lwb72swb Electrical 4 03-23-2008 03:35 PM
headlight help hotrodkb1 Electrical 7 08-13-2007 06:04 AM
headlight pigtails 50jimmy Electrical 4 05-10-2007 08:43 AM
H4 headlight conversion Blackdog Electrical 1 03-04-2005 01:36 AM
