Hey Y'all.
After cleaning out all 4 of the local parts stores today of their headlamp adjustment screw kits I am looking for a better option, I am trying to find a GOOD option for my Chevy Truck 85 & 88 . NOW I have run into multiple problems. ~#1 The slot on the Help #41129 screw is not wide enough to slip over the light bucket. ~#2 When I use the old screws they do not bolt on {grip} the threads on the plastic part , Maybe a smaller Diameter. ~#3 The plastic part is cheap & breaks if you can get it to stay in at all. ~#4 the Old ones are shot & I need head lights I am thinking about trying a double jamb nut on the bolt but it will be a real PITA to adjust, Seeing I do them @ night to get a true projection. I would be interested in any & all Ideas & previous remedies . Thanks for taking the time out to read this. Rob
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
you'r going to have a little trouble trying to use nuts..1 on front &1 on back of sheet metal....
how about looking at a dealer??? i've found good luck in the HELP parts line... you might have to do some mod's.if too large..but then you can adj. lites with-out having to play around with nuts.. usually the bolts are going into plastic,,helps keep them from vibrating around.... |
Chris,
Thats not a bad Idea I did not have time for a full out repair {no time for the epoxy to cure. The Screw is metal then it goes into plastic rectangled clip then the plastic goes into the metal of the radiator support. bobjob , Thats what got me into this mess . What a PITA!!!! I went to replace the high / low beams & the plastic crumbled well then the "HELP" crap I think is "Dorman" {they are going to get a letter from me} The screw the slot is too narrow will not slide over the head light bucket AND! The plastic breakes so easy & does not fit into the rectangle on the rad support, So I tried to use the old screws but they strip out in the new plastic & will not adjust up at all A waste of time & $$$$!! SO what I did was find some Nuts & Flat washers & leave them loose until night time came ,then adjusted them as close as I could by sight in the road in front of my house then tighten the nuts on both sides . 2 washers & 2 nuts on each screw 1/4" X 20 . I got the passenger side done & gave up. I had to drive it. So it worked for now I wonder if the dealer would carry them? I did not see them @ LMC Thanks Y'all I will write them now while I am still pizzed Rob
| setting points on sb chevy | frackster66 | Electrical | 14 | 03-22-2008 11:33 AM |
| I'm going to make a bonfire out of my car | blown69stang | Engine | 36 | 08-22-2005 03:36 PM |
| headlight adjustment | fred56 | Body - Exterior | 3 | 07-06-2003 06:05 AM |
| headlight adjustment | fred56 | Body - Exterior | 2 | 07-04-2003 12:09 PM |
| Idle mixture screws only turned out 3/4. Runs good. | BrackneyC | Engine | 1 | 04-28-2003 03:58 AM |
