Headlight Braces - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2007, 01:18 PM
Last journal entry: Headlights added
Headlight Braces
Can any post a few picks of the location on the frame where the headlight/fender braces mount?
Thanks,
Steve
Old 05-15-2007, 01:22 PM
302 Z28's Avatar
Steve, the headlights bolt to the front fender brace on the 34's. The fender brace bolts to holes in the frame rail. If you have an IFS some of those holes are covered up. I had to modify the fender brace to go around the IFS mount. I welded a tab on top of the frame drilled and tapped it to capture two bolts for the fender brace.
I'm at work currently, when I get home I will search for some pics, I have them.
Vince
Old 05-15-2007, 01:29 PM
Vince,
My frame is TCI, can I think the 1st owner weld them up.
Steve
Old 05-15-2007, 01:31 PM
302 Z28's Avatar
Chances are TCI did it when they installed the IFS.
This link gives an idea of what is involved.
Vince
Old 05-15-2007, 01:40 PM
302 Z28's Avatar
Steve, found this in the Hotrodders project journals. Wish I had found this before I modified mine. The end result was the same, but he did a much nicer job of it.
Vince
Old 05-15-2007, 01:48 PM
OK, So I think I will need to modify the brace but how do you know how far back to front it should be how do I determine the location on the fender as this would tell me where it needs to be on the frame.
Steve
Mini Cooper S Headlight Wiring tc33 Electrical 5 11-24-2006 01:17 PM
Calling the DOC..66 Impala headlight switch issue black66 Electrical 7 06-01-2006 04:46 PM
Headlight burned or what? 69ChevelleAddict Electrical 3 07-18-2005 08:00 PM
older headlight switch smoking! bigfred1958 Electrical 9 02-15-2004 09:31 PM
Wiring Headlight Switch horvath Electrical 7 05-10-2003 08:36 AM
